Old Sat, Jun-23-2018, 10:14:25 PM   #21
Edgy
Constantly Learning M3 and M5 Owner
Edgy's Avatar
Reputation: 0 Edgy is on a distinguished road
Default Re: Pre Purchase inspection
I've never understood that view.
Seller could be a regular customer. Buyer some guy dealer will never see again, esp. if buying long distance. There's a chance PPI will lean in the seller's direction. Also, if PPI finds a lot of stuff obvious question would be, why didn't the dealership already address?
Maybe you have a higher faith in human nature than I do. Skepticism is healthy when buying a car.
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Jump to top Edgy is offline   Reply With Quote
Old Tue, Jul-03-2018, 03:59:16 PM   #22
Analog///M
Analog///M's Avatar
Reputation: 0 Analog///M is on a distinguished road
Sorry for the late post. Morristown BMW PPI report came backfor the 04 IR/IR 48K with Rear spring R/L broken,Brake flush,all Belt need to be replace due aging/weathering $2,600.00 at the dealer. I decide to pass on the car. I was told on the phone the car recently pass it own PPI( seller argued with Morristown BMW that the report was wrong. Morristown BMW stood by their report. After a week the seller offer to pay for the repair to move the car. With me being out of state and looking for investment grade car Morristown BMW stated the only records it could pull up for the car was the 1st oil change (no breaking in svc records or any records to speak of. and air bags recall still open.
Which bring me to another 06 E46 M3 I found interest located in Cali... can anyone recommend, E46 M3 specialist in Mountain View Cali? or should send this one to the local BMW shop? this car has all records, only svc at bmw dealership from new all keys books & window sticker,
Jump to top Analog///M is offline   Reply With Quote
Old Tue, Jul-03-2018, 04:16:22 PM   #23
mrgizmo04
mrgizmo04's Avatar
Bavarian Motorsport in Milpitas
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jul-03-2018, 08:42:28 PM   #24
Analog///M
Analog///M's Avatar
Thanks.
Old Tue, Jul-03-2018, 09:41:38 PM   #25
qualicas
qualicas's Avatar
Am I missing something? 1 broken spring and 2 belts and brake flush $2600??
Sounds like the car was in almost perfect shape. Broken spring is not uncommon. Replacing rear springs (do both) would be a simple job. Replacing belts is a bit of a pain but otherwise simple. Brake flush do while rear wheels are off for springs.
Old Tue, Jul-03-2018, 09:41:48 PM   #26
simon_c
Reputation: 0 simon_c is on a distinguished road
Edge Motorworks in Mountain View is a good shop.
2004 M3 - Alpine White | Impluse Cloth | 6MT
2002 M3 - Alpine White | Cinnamon | 6MT (past)
Jump to top simon_c is offline   Reply With Quote
Old Tue, Jul-03-2018, 10:55:22 PM   #27
Analog///M
Analog///M's Avatar
(I know what you mean about the repair cost it was a very clean car but I want M3 E46 with all 3 keys books record and window sticker)This was the price at Morristown BMW and thing always cost more at the dealer. The seller repair the car for half the price and sent the completed invoice but was no longer interested.
Old Tue, Jul-03-2018, 10:56:21 PM   #28
Analog///M
Analog///M's Avatar
I will call after the 4th.
Old Fri, Jul-06-2018, 03:28:05 PM   #29
Al Soobie Guy
Reputation: 0 Al Soobie Guy is on a distinguished road
If you dont have the money to pay someone else to fix an M cart without bitching and moaning and calling bankruptcy, you should at least be able to do the work yourself. There is no in-between. Its an old car that will need shit ton of work sooner than later. Boils down to the fact that you dont seem to have any understanding of the estimate they gave you all you saw was the $$$ and upsell maintenance
You should be buying a Honda, because you passed on a reasonable M3.
Jump to top Al Soobie Guy is offline   Reply With Quote
Old Fri, Jul-06-2018, 05:55:38 PM   #30
bostonbruck
bostonbruck's Avatar
Reputation: 0 bostonbruck is on a distinguished road
That car only needed $350 of repairs. You could have easily done that at home. The estimate they gave you is way too high
2002 Jet black 6MT Coupe Beisan Vanos, Gloss black grills, F10 M5 knob, Supersprint Race Muffler, Powerflx rtabs, maintenance
Jump to top bostonbruck is offline   Reply With Quote
Discussing Pre Purchase inspection in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
