Old Thu, Jul-12-2018, 03:27:28 PM   #101
Default Re: Best BBK for E46 M3
Originally Posted by BTB View Post
What's the issue with the smaller ones, reduced engagement of the hub shoulder in the wheel?
Yep-- especially when combined with the loads track tires (/tracking) puts on them.
Old Thu, Jul-12-2018, 03:44:34 PM   #102
bigjae1976
Default Best BBK for E46 M3
The biggest problem is while the hub lip is 10mm, most wheels have a chamfered bore.
With a 5mm spacer you might only have 1-2mm of engagement between the wheel bore and hub lip.
A 5mm to 9mm spacer is asking for trouble.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Jul-12-2018, 03:52:20 PM   #103
BTB
BTB's Avatar
Hmm okay.. makes sense. What exactly is that lip doing other than precisely locating the wheel against the hub? I wouldn't think it would really be under load during hard cornering, as the lug bolts/nuts are farther away from the wheel axis and already stressing the wheel against the hub..? Just trying to understand
Regardless, I doubt I would have issues running soft 225 winter tires. But still I was thinking of using for track too, Bimmerworld offers those used Hoosiers in 225/45/17
My Journal
Old Thu, Jul-12-2018, 03:55:40 PM   #104
bigjae1976
Thatís what itís doing. Thereís a lot of force going through the hub in multiple directions.
You might get by on the street not using hub centric wheels or spacers but it wonít last long on track before you at best get a nasty vibration. Iíd put money on one or more wheels coming off.
Old Thu, Jul-12-2018, 04:23:26 PM   #105
BTB
BTB's Avatar
Okay but even if the lip is only partially engaged with the wheel, aren't the lugs taking most all of the force from the road? Like I said they are much farther from the wheel axis so if the wheel is always flush with the hub at the lugs I don't imagine there's much movement where the wheel sits on the lip? What are the possible consequences for a minimally engaged wheel/lip under high loading conditions?
My Journal
Old Thu, Jul-12-2018, 04:32:04 PM   #106
bigjae1976
Iím sure thereís some fudge factor designed but you really need to make sure you maximize the contact area.
The lugs just hold the wheel against the hub. Not sure what the term is but the hub is what keeps the wheel centered. If you didnít have the lip, your lugs would take most of the force. They wonít last long.
Theyíll bend back and forth as the wheel rotates and fail.
Old Thu, Jul-12-2018, 04:36:42 PM   #107
BTB
BTB's Avatar
Ahh okay I guess I see. Particularly under braking I can see the hub lip doing a bit of work, but I'm sure in cornering too. I was under the impression the friction between the wheel and hub (caused by the lugs which are stressed) plays a big roll in keeping the wheel from moving around too but I could be wrong
My Journal
Old Thu, Jul-12-2018, 07:44:42 PM   #108
BTB
BTB's Avatar
Apex says the 17x9 et30 should fit over the brakes, actually offering ~2mm more clearance over 17x9.5 et35. They think a 3mm spacer might work, sounds like the right route for me
My Journal
Discussing Best BBK for E46 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
