Old Sun, Jun-01-2008, 10:36:59 PM   #11
kiloil
kiloil's Avatar
Reputation: 0 kiloil is on a distinguished road
Originally Posted by ArtM3 View Post
just looked at the TIS...look at the realoem diagram, item 7...it's a nut that goes on that bolt...it's missing on yours
did you remove it?
you should be able to tap the bolt out...
not sure if this helps....
I managed to get the nut off.
I haven't tapped the bolt yet in fear of messing something up, plus the lack of room doesn't warrant a swing of a hammer, or a dead blow. I need to see if I can lower the tranny down about 2 more inches (already removed the skid plate, fan housing, motor mount nuts, cabin air filter area)
Also found this informative website.
http://www.anicecupofteaandasitdown....mw_pdf/SMG.pdf
2009 E92 M3 MT (Gone)
2011 4 Runner Limited 4WD (Gone)
1996 4 Runner 4WD (Too sendimental to get rid of)
2013 E92 M3 MT (Gone)
2015 25 SLX Sea Ray 8.2L Magnum Big Block.
Jump to top kiloil is offline   Reply With Quote
Old Sun, Jun-01-2008, 11:03:49 PM   #12
Tonester
Reputation: 0 Tonester is an unknown quantity at this point
Viet Nam
To get the tranny to come down more you'll need to "jack up" the front of the motor... use a piece of 2x4 in between so nothing gets damaged.
Jump to top Tonester is offline   Reply With Quote
Phelps Vs Bolt zeuiax Off Topic 13 Wed, Aug-20-2008 06:31:27 PM
Can I just replace this bolt....? junhimSELF E46 M3 (2001-2006) 5 Thu, Mar-13-2008 06:16:45 AM
wiper bolt? madkimchi E36 M3 (1992-1999) 0 Tue, Dec-04-2007 05:10:36 AM
Question on bolt-on HP widjajachandra E46 M3 (2001-2006) 1 Tue, Apr-26-2005 08:18:43 PM
Bolt-on for 44 HP! m3 driven E46 M3 (2001-2006) 4 Tue, Jun-17-2003 04:55:28 AM
Discussing Ever seen this kind of bolt in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
