Old Tue, Aug-02-2016, 02:27:12 AM   #1
eatsleeplax
Car Enthusiast
eatsleeplax's Avatar
Reputation: 0 eatsleeplax is on a distinguished road
Default Vanos High Pressure Oil Line repeat failure (1 year)
Has anyone had the high pressure line from the vanos to the accumulator (#2 here) fail repeatedly? I replaced it exactly a year ago (with the updated OE part) and now it seems to be failing in the same exact spot (where the hard line meets the soft).
For reference, the vanos unit was also replaced with an OE unit from the dealer at 87.5k miles (in 2012), currently at 116k.
Wondering if this could be indicative of another issue, maybe with the vanos pressure regulator?
Jump to top eatsleeplax is offline   Reply With Quote
Old Tue, Aug-02-2016, 02:38:33 AM   #2
Hacksaw
What broke now?
Hacksaw's Avatar
Reputation: 0 Hacksaw is on a distinguished road
Default Re: Vanos High Pressure Oil Line repeat failure (1 year)
Its possible.
When you installed the replacement, did you have it bent a little to flex towards the engine block in a smooth arch?
Not saying it's installed wrong, just asking as a data point. It's also possible you got a bad compression there at the join.
'02 BMW ///M3
Imola Red|Blk Cloth|6MT|FS CSL Custom TUNE -MSS54HP|CSL Replica Airbox|Euro Headers|BimmerWorld 3.5" race front Y and resonator|Hacksaw's custom 3.5" SS exhaust system w/Magnaflow and 4 tipped goodness|SGT RS-ENR Coilover Kit|Evo Sport Performance Pulley Set|CDV Delete|UUC USS & DSSR|Sparco Roadster Seats|StopTech ST-40 BBKs on all 4|Beisan Systems vanos rebuild w/original stock exhaust hub|Kirk 4 point roll bar|CF CSL Rep Trunk|GC Race F/R Sway Bars|TR Motorsports MT-1|Avin Avant 2|Seibon CF GTR Hood
Jump to top Hacksaw is offline   Reply With Quote
Old Tue, Aug-02-2016, 02:50:30 PM   #3
playskool1
NorCal's S54 S65 S85 Rod Bearing spc.
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
I haven't had the issue but I went with the Rogue Engineering VANOS High Pressure Hose. I've heard a lot of these busting before so I didn't want to risk running it stock. They say it should be replaced annually but I highly doubt that. At least I know their hose holds higher pressure than the stock ones and it is stainless steel braided and flexible.
01/01 build date[LSB][Cinn.][6 Spd.]MAXIMUM PSI TURBO 14psi PT6266 [230k total miles][original motor]
[115k supercharged miles][17k E85 miles][9k turbocharged miles][1.9k track miles]
INSTAGRAM: @skweakykleen
Full Beisan VANOS overhaul, TMS Subframe Reinforcement, WPC rod bearings = bulletproof
fully built S54 w/ Precision 6870 coming soon!
Jump to top playskool1 is offline   Reply With Quote
Old Sun, Oct-21-2018, 06:24:28 PM   #4
BubbaTree
BubbaTree
Reputation: 0 BubbaTree is on a distinguished road
I'm thinking of using the Rogue Engineering hose as preventative maintenance, and am wondering how yours is doing after 2 years?
Regards,
Steve
Jump to top BubbaTree is offline   Reply With Quote
Discussing Vanos High Pressure Oil Line repeat failure (1 year) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
