Old Mon, Oct-22-2018, 12:24:00 AM   #51
Default Re: Chach's DIY Porsche 996 BBK Conversion extensive write up
Looks like you've got the wrong pads. Keep in mind there are a lot of variations on brembo calipers and pads from all sorts of porsches, so part #s need to be exact.
I don't think it's possible that the po was running 325mm rotos and now you're running 345mm. If that were to happen, your fitment would be way off. The bracket is different and you're talking about a 6.5mm swing from calipers machined for 325mm vs. 345mm.
Your fitment seems fine to me, just a slightly incorrect pad - again, remember there are lots of similar pads for lots of varying 4 piston brembo calipers so it doesn't surprise me that your fitment looks as good as it does considering that you've got the wrong pads.
Also, are you using dampers? I found, with new pads, rotors and dampers, it was all a little too tight and the wheel was stiff to turn. Removed the dampers and everything's perfect now.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats zero options ~3200lbs JOURNAL
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
OE CSL trunk Sportline 8S 18"x8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Mon, Oct-22-2018, 12:48:07 PM   #52
Originally Posted by M3AZ View Post
I just bought some used 996 calipers for this project. Anyone know if 17 wheels work with this setup?
Shorter answer: it depends on the wheel, but generally not
Longer answer:
I tried the 17" BBS RG-R from my M3 wagon, as well as one of the stock e46 17s from it (which I use for snows), and neither cleared.
On the other end of the spectrum, I have 17" Apex ARC 8s that are specifically designed for brake clearance as my M3 coupe's track setup-- and it clears my Brembo 355/4 setup (considerably larger than this).
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5,04 M3 wagon, 2017 i3
Old Mon, Oct-22-2018, 01:09:55 PM   #53
CSLM3Wannabi
Reputation: 0 CSLM3Wannabi is on a distinguished road
Just installed my fronts this morning. It could be the wrong pads, but looks more like the calipers were not machined.
2005 BMW M3 ZCP Nardo Gray | ESS VT2-550 | Dinan Throttle Bodies | 6MT Swap | Active Autowerkes Headers + Section 1 w/ 100 cells | Miltek Section 2 and 3 | KW V2 w/ GC camber plates and Eibach Front and Rear Swaybars | Porsche 996 BBK upgrade w/ OEM ZCP rotors | Umnitza V4 Angel Eyes | Euro bumper w/ Morimoto led fogs | 1 piece Carbon Lip | VIS XTS Full carbon hood | SCZA Carbon Fiber CSL Trunk | Carbon Fiber CSL Diffuser | Square ZCP Wheels |
Jump to top CSLM3Wannabi is offline   Reply With Quote
Old Wed, Oct-31-2018, 04:57:37 PM   #54
Branden246
Reputation: 0 Branden246 is on a distinguished road
Have a quick question for you guys regarding this. I have seen people running front “non-s” Boxster pads in the rear on this conversion. Is this a bracket specific application or it doesn’t matter? I’m looking at the road rally and ecs bracket adapters. There isn’t much on the ecs brackets that say you can run front non-s pads in the rear. I’m fine with just running the standard rear pad, but if I can fit larger ones then why not.
Jump to top Branden246 is online now   Reply With Quote
Old Wed, Oct-31-2018, 05:02:45 PM   #55
I believe the RR brackets will allow you to run the base boxster front pads on both sides of each caliper, but the CM brackets from ECS won't allow you to run that pad on the inside of each caliper, but you can use the pad on the outside to avoid the rust ring. There'll be a rust ring on the inside of the rotor, but you'll never see it.
_
Old Wed, Oct-31-2018, 05:24:54 PM   #56
Branden246
Thank you. Now comes the tough call. Get rally road and run the larger front pad in the rear, or get the CM brackets and run regular rear pads.
Is there much difference between the rally road and ecs (CM) brackets?
I have the calipers already, getting them machined at my work, and have my lines picked out. Just deciding on the brackets now.
Old Wed, Oct-31-2018, 05:50:48 PM   #57
rickyboycz
Reputation: 0 rickyboycz is on a distinguished road
I'm running the RR rear brackets with the non-S front pad in the rear.
No issues, but can't answer whether one is better than the other. In the end I would imagine from a performance perspective the affect is negligible and wouldn't translate to any more brake torque with the larger pad.
Jump to top rickyboycz is offline   Reply With Quote
Old Wed, Oct-31-2018, 07:41:55 PM   #58
I just explained how you can still use the boxter pads in the rear with either bracket maker.
_
Old Wed, Oct-31-2018, 08:02:12 PM   #59
CLAWHAMM3R
BELOW M3
CLAWHAMM3R's Avatar
Reputation: 0 CLAWHAMM3R is on a distinguished road
My experience with the RR rear brackets and the pads is documented here:
http://www.m3forum.net/m3forum/showthread.php?t=512078
TL;DR: depends on the pad thickness if you can run the taller pads on both sides of the rears with the Rally Road bracket (unless they updated the design again).
2004 ///M3
Jump to top CLAWHAMM3R is offline   Reply With Quote
Old Wed, Oct-31-2018, 08:13:40 PM   #60
Just from a visual comparison of the brackets, I can see that RR machines them slightly differently, presumably, to give room for the pad, so I would assume that they did update it, but perhaps not. I can't say for sure, just that there's an obvious difference in the brackets where that contact would occur - you'd expect that they wouldn't have tried and failed with a design that would allow boxster front pads.
Furthermore, I believe the RR site is where the instructions are to go ahead and use front boxster pads to avoid rust ring.
_
Discussing Chach's DIY Porsche 996 BBK Conversion extensive write up in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
