Old Sun, Mar-04-2018, 02:17:32 PM   #1
ctres
ctres's Avatar
Reputation: 0 ctres is on a distinguished road
Default Calvin's E30 S54 Swap
I've had this project in the works for over a year now but I'm finally making decent progress so I figure it would be a good time to start a thread to document it. I'm a little late in starting this, so I'll post photos and videos as I get time.
I ran across a good deal on an S54 with a bunch of spare M3 parts on craigslist in Fall 2016. I had no chassis to put it in but I had been wanting to do an E30 swap for a long time so I scooped it up anyways. The search was on for a clean E30 chassis to drop it into, but in the meantime I stripped the engine down to the long block and started cleaning things up.
Picking up the S54 and a bunch of other M3 parts that came along with it.
The S54 in all it's glory on the engine stand
Long block being stripped down for repaint. Stay tuned, I figured I'd go with something more exciting that the standard black paint.
Fast forward to Summer 2017 and I finally found a good chassis locally. It was a 91 318is in Alpine white. The car had been an Arizona car for it's entire life up until about a year before I bought it, and had never been driven in a Michigan winter so there was no rust to be found. Everything else on the car is a bit rough, and the odometer had stopped at 225K, so it's had a long life but the chassis seemed solid and I wasn't concerned about the drivetrain so I took the dive.
Here's a few glamour shots of the E30 shortly after I got it. The cosmetic issues are readily apparent, but I'll get to those later. For the moment I'm happy to have found a rust free late model E30 for a reasonably price.
I got distracted working on my M3 that summer and fall, so the E30 didn't get much attention except for the occasional burnout and hooning here and there.
Meanwhile the S54 sat on the stand for quite some time without getting much love. Finally just after New Years 2018 I got around to buying a new suframe and pulling the S54 oil pan to send out to Arc Asylum for Tyler to do his modification to retain the stock S54 oiling system in the E30 chassis. I got back to work on the engine and started getting serious about accumulating parts for the swap.
We got the car inside, which was a struggle since it barely wanted to stay running and the battery was totally dead from sitting in the freezing cold for 4 months. It was making some pretty awful noises at this point but I managed to limp it in. More on this later. My buddy helped me pull the stock M42 engine and thanks to the lack of rust, everything came apart without any issues and we managed to get the engine and trans out together pretty easily in just two evenings. We don't normally have that luxury working on cars from Michigan so that certainly made the process less frustrating.
Tucked away in the corner
Hood off
Everything mostly disconnected up top, getting the engine ready to pull
Out with the old!
Mostly empty engine bay before I removed the last few things. Since this photo I removed the purge canister, and AC lines, condenser, and electric fan
I also picked up a ZF 5speed, steering rack, and power steering pump from an E36 328i in a local junkyard. This will make a nice improvement to the steering, and the ZF mate up to the S54 with an E46 M3 clutch and pressure plate and an E34 M5 clutch. I'll be using an E36 328 or M3 driveshaft which should bolt right up with the E30 CSB.
ZF 5spd + all the mess from the M42 removal
With the M42 out I made my first repair to the E30! I swapped out the blower motor resistor and got functioning heat again. I pulled the AC condenser, fan, and AC lines since I don't plan to have functioning AC. I want to keep weight off the front end, since the S54 upsets the weight balance a bit already, and I don't feel like dealing with the CAN interface required for proper operation of the AC compressor with the S54. However, I need the blower working so I can at least have windshield defrost functional. I figure I'm saving about 40-50 lbs by not having AC. The metal fan on the E30 condenser was surprisingly heavy. I'll have to weigh everything to get a final number.
Jump to top ctres is offline   Reply With Quote
Old Sun, Mar-04-2018, 02:22:01 PM   #2
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Default Re: Calvin's E30 S54 Swap
Sounds like an awesome project. Looking forward to updates.
Old Sun, Mar-04-2018, 11:48:25 PM   #3
ctres
ctres's Avatar
Thanks, I can't wait. Stay tuned for updates.
Old Mon, Mar-05-2018, 02:55:23 AM   #4
youinreverse
Reputation: 0 youinreverse is on a distinguished road
I'm always in for a good build thread. This should be awesome!
Jump to top youinreverse is offline   Reply With Quote
Old Wed, Mar-07-2018, 07:04:47 PM   #5
killa_e46
killa_e46's Avatar
Reputation: 0 killa_e46 is on a distinguished road
Excited to see the progress on this build
Jump to top killa_e46 is offline   Reply With Quote
Old Sat, Mar-10-2018, 07:35:12 PM   #6
Sebaflex
Sebaflex's Avatar
Reputation: 0 Sebaflex is on a distinguished road
Sounds good.. sub'd
- Seb
Jump to top Sebaflex is online now   Reply With Quote
Old Tue, Mar-13-2018, 01:27:51 AM   #7
ctres
ctres's Avatar
Original post updated with photos. We completed the autopsy of the M42 on Saturday. Did I mention it was making bad noises? Yeah, well it turned out nearly all the main bearings had spun. I knew it was losing oil all along, but hadn't bother to trace down the leak since I really didn't care what happened to the M42 and I knew I'd be pulling it sooner than later anyway. Turns out running it hard with very little oil tends to expose the ummmm... shall we say 'weaknesses' of the engine (or possibly the owner).
Here's a photo of the crank. All the main journals had seen better days, but but damage on the one in the middle of the pic is particularly bad. You are actually seeing the outside of the bearing shell there. The two halves of the shell welded themselves together and formed a ring that can be spun around the main journal.
And a photo of the head which actually seemed to be in good shape. Turns out there is still a market for a lot of parts from these engines and I've been able to part some stuff out. Not bad since I had just planned on scrapping the whole thing.
Anyway, enough of the old, the S54 bottom end looks healthy and I started replacing the rod bearings on Saturday with new OEM WPC treated bearings. I got 3 cylinders done but it was getting late so I'll finish the rest this week.
Assembling with redline assembly lube
I'll post photos of all the shells once I finish the rest of the cylinders. All three that I pulled showed a small amount of copper on the rod half. Nothing major, and certainly not bad compared to some of the ones I've seen posted by others here. However, it was a good reminder that doing this is worthwhile, especially when it's easy with the engine out like this. I belive this engine has around 130K miles on the original bearings. I did find a vanos tab in the oil pan unfortunately, so I had to bite the bullet and buy a new hub to the tune of $400. Vanos bulletproofing with Beisan parts is next on the agenda before the engine goes in the car.
Old Wed, Apr-18-2018, 12:17:49 AM   #8
ctres
ctres's Avatar
It's been a while since my last update and progress has been slow. I've been accumulating more parts and discovering more hurdles as I go.
I found that one of my rod bearings was damaged in handling/transit, so I have 5 done and I'm waiting on a replacement to finish installing them. I found a good vanos hub, so Beisan fixes will be next along with new paint for the engine block.
I rolled the car outside on a warmer day and cleaned out the engine bay and got rid of a lot of the dirt and grease.
In doing so I unfortunately discovered that there was some damage to the chassis legs at some point in the car's past. I knew it had been in front end collision at some point because the radiator support was a bit bent up in one spot, but I didn't think it was enough to affect the legs. If you look closely you can spot it. I'm still trying to decide how to proceed from here. If anyone has any tips feel free to let me know. The safest course of action would probably be to take it to a frame shop to check it for straightness and adjust as necessary.
In the meantime I've been figuring out my fuel system and a bit more wiring. I got an Aeromotive 340LPH pump which is overkill, but seemed like a quality option. I'll be installing it in place of the stock 318is fuel pump in the tank. Stock rubber lines are 8X13mm, so I got some replacement CRP line and I'll be replacing any rubber lines that need it (probably all of them). I'll be using a stock 318is fuel filter in the stock location. The fuel supply and return line come up to the engine bay right near the left side chassis leg/strut tower. I'll be installing a stock E46 M3 FPR in this location and connecting it to the fuel rail with either an E46 or E36 line.
I also dug into the wiring harness a bit to delete the SMG connections that won't be needed. More details to follow on that, but this certainly helped to remove much of the bulk.
For the brakes I got a used booster from a BMW 2002. This will bolt up to the firewall and the master cylinder will fit right on it. The rod for the clevis will need to be modified. From what I've read it sounds like this will clear the manifold. If not I'll likely modify the manifold or move the booster to the left.
I also installed garagistic delrin shift carrier bushings and a new selector shaft seal on the ZF trans. The input and output shaft seals looked dry so I didn't mess with them. I also purchased a new collar thingy that goes around the input shaft, new shift fork, and steel pivot pin as well as garagistic poly bushings. I have a new Sachs E34 M5 clutch and used E46 M3 flywheel and pressure plate with low mileage that I'll be using to pair the engine to the trans.
I have a steering rack from an E36 328i that I'll be installing once I get my subframe back from Arc Asylum. The E36 rack is 3.2 turns lock to lock vs. the stock E30 rack which is about 4 turns. I'll be using an E36 power steering pump and lines. The Arc Asylum subframe is being made so that an E36 rack is a direct fit with no spacers needed. I need to make some slight modifications to where the column comes through the firewall to make everything line up since my car is equipped with an airbag. Earlier non-airbag E30's are a bit easier.
Discussing Calvin's E30 S54 Swap in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
