Old Tue, Dec-19-2017, 11:33:00 PM   #611
2004LSB
Reputation: 0 2004LSB is on a distinguished road
Default Re: Streamline & Dr M3an M3's CSL Airbox Development Journal Collaboration
Good stuff!! I'm definitely interested in this project -- will there be another group buy opportunity in May 2018? I would like to see the final product after refinements / improvements have been made on the initial prototype.
Also interested in the full MAP sensor and OE filter setup!
Thank you Antony!!
Jump to top 2004LSB is offline   Reply With Quote
Old Tue, Dec-19-2017, 11:55:12 PM   #612
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Thank you Antony!!
No idea about May 2018 specifically, but yes we will run multiple Group-Buy rounds for as long as demand exists.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune.
Active Group-Buys (PM if Interested): OE CSL Bootlids, Supersprint Headers/Exhaust MEGA thread, New Supersprint Oversized Twin-Piped Section 2 ...and more to come!
Please PM me - In search of: Nothing at the moment.
Old Wed, Dec-20-2017, 12:05:04 AM   #613
PITT M3 RR
PA
PITT M3 RR's Avatar
Paffy, appears to have been able to modify the CSL full binary for use in an HP without the flap. Simply purchase his program, Virginize the (HP) DME, load the full modified CSL binary which can be found on msstuning.com, then flash the partial (smg or 6MT) depending, both of those are also on the site and thatís should be it.
THREAD: Running CSL software on MSS54HP
SITE : http://www.msstuning.com/mssflasher.html
VIDEO
Youíll need the Bosch map sensor still (few options w/ same calibration at the moment ) https://m.ebay.com/itm/Manifold-Abso...-/222308924794
This is an alternative to the OEM unit, heres a thread with info.
CSL map sensor alternatives
Correct me if I am wrong anyone? This is just one more option for the DIYíer, Iíll be going this route with a spare HP minus EWS.
S54 E36 BUILD
Jump to top PITT M3 RR is offline   Reply With Quote
Old Wed, Dec-20-2017, 12:18:53 AM   #614
But, it's not essential as Anthony wrote. I'm running an airbox w/ filter and I only used new boots, hose clamps, alpha N tune & some cheap silicone hoses and clamps for the ventilation. You don't have to have:
6 x Clamps (59 - 66mm) (07129952125)
2 pole socket housing for CSL IAT Sensor (12521427615)
CSL IAT Sensor (13621739510)
90 deg protective boot for 2 pole socket housing (12521732635)
CSL Crank Case Vent Hose (11157833649)
CSL Airbox Air Shut Off Valve (11617833647)
and the CSL ECU or csl tune on msss54hp
I'm not saying this stuff isn't nice to have or anything like that, only saying it's not essential.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats zero options ~3200lbs JOURNAL
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies WPC'd OE bearings oil catch can fan/SAP/washer delete CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/550) + tall RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates SPC alum rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
OE CSL trunk Sportline 8S 18"x8.5/9.5" MPSS 245/275 APEX 75mm Studs 12mm/10mm F/R spacers Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Wed, Dec-20-2017, 01:34:13 AM   #615
Cmda17
Reputation: 0 Cmda17 is on a distinguished road
1. Kwakjoe
2. Xrumx
3. Good
4. PITT M3 RR
5. Ramp1
6. SQ13
7.Chasen
8.aznbo187
9. lippstuh
10. . (just so I don't get confused -- his name is dot ".")
11. Chapelle
12. Droplets
13. Sashman123
14. RunwayM
15. Cosmos///M3
16. Jovica
17. MrCooperS
18. mcmahonbj
19. Sweet Jones
20. jchan112
21. bbrtuning
22. Braymond141
23. Jeffy JJ
24. E30toF30
25. 10speed
26. aaronpoweruser
27. ZiMMie
28. T-Rex
29. empty
30. Lakere46*
31. HD-M3
32.bimmerrodg
33. mitch500
34. OneFastSicilian
35.TheGenius46M
36. m3az05
37. nervous24
38. SliM3
39. ldev869
40. e46IX
41. killa_e46
42. Kdubski
43.BigLooga
44. bjz
45. na2boost
46. Tig368
47. Nickdk
48. Dferreira
49. JohnDoe - Z4M
50. JohnDoe - E46 M3
51. Shainz ó CF e46 m3
52. ATB88 - CF E46 M3
53. silvergray545 - CF E46 M3
54. marioec
55. Cmda17
Jump to top Cmda17 is offline   Reply With Quote
Old Wed, Dec-20-2017, 07:35:59 AM   #616
Topaz_46
Reputation: 0 Topaz_46 is on a distinguished road
1. Kwakjoe
2. Xrumx
3. Good
4. PITT M3 RR
5. Ramp1
6. SQ13
7.Chasen
8.aznbo187
9. lippstuh
11. Chapelle
12. Droplets
13. Sashman123
14. RunwayM
15. Cosmos///M3
16. Jovica
17. MrCooperS
18. mcmahonbj
19. Sweet Jones
20. jchan112
21. bbrtuning
22. Braymond141
23. Jeffy JJ
24. E30toF30
25. 10speed
26. aaronpoweruser
27. ZiMMie
28. T-Rex
29. empty
30. Lakere46*
31. HD-M3
32.bimmerrodg
33. mitch500
34. OneFastSicilian
35.TheGenius46M
36. m3az05
37. nervous24
38. SliM3
39. ldev869
40. e46IX
41. killa_e46
42. Kdubski
43.BigLooga
44. bjz
45. na2boost
46. Tig368
47. Nickdk
48. Dferreira
49. JohnDoe - Z4M
51. Shainz — CF e46 m3
54. marioec
55. Cmda17
56. Topaz_46
Jump to top Topaz_46 is offline   Reply With Quote
Old Wed, Dec-20-2017, 02:04:23 PM   #617
tjkenny15
tjkenny15's Avatar
Reputation: 0 tjkenny15 is on a distinguished road
UGH I am so on the fence about getting in on this...
What to do
2005 BMW M3 INDIVIDUAL - Estoril Blue
Jump to top tjkenny15 is offline   Reply With Quote
Old Wed, Dec-20-2017, 02:19:44 PM   #618
killa_e46
killa_e46's Avatar
Reputation: 0 killa_e46 is on a distinguished road
What to do
You should definitely hop on this GB
Also just realized you are in Tysons! I'm in Reston, lmk if you are at the Katies Cars and Coffee when its nice weather out.
Jump to top killa_e46 is offline   Reply With Quote
Old Wed, Dec-20-2017, 04:44:27 PM   #619
Cha5en
Banned
Reputation: 0 Cha5en is on a distinguished road
I may hit you up for help installing as Iím wondering how much is really needed to get rhe box to work
Jump to top Cha5en is offline   Reply With Quote
Old Wed, Dec-20-2017, 05:09:35 PM   #620
Ya let me know, happy to help.
_
Discussing Streamline & Dr M3an M3's CSL Airbox Development Journal Collaboration in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
