Old Sun, Nov-19-2017, 05:36:12 AM   #111
bimmerdriver
Reputation: 0 bimmerdriver is on a distinguished road
Default Re: DIY: E46 M3 (S54) detailed valve adjustment
Originally Posted by Kalahari View Post
Question - I have observed others, and was taught myself, to turn the motor by using a wrench on the camshafts rather than the front fan nut. See here, between cylinders 1 and 2, where the camshafts are not round:
I have not seen online anyone else do this... I am wondering if I was taught incorrectly or if this is an acceptable method, as it saves from having to remove any of the fan components.
I would not do this, nor would I advise anyone to do this. the timing chain and tensioners were designed for the load to be driven from the crankshaft, not the camshaft. maybe it's not a big deal, but I would just stick with that, since you also have to align to TDC using the damper anyway.
2002 (12/2001) M3 6MT Coupe Carbon Black on Black - ZCP/CSL Wheels, 245/35/19 Mich PS2 & 285/30/19 Conti ExtremeContact DW, H&R 15 mm Front Spacers, CSL F/R Brakes, EBC Redstuff, TMS SS F/R Brake Lines, PSS9, TMS F/R Sway Bars, TMS Rear Control Arms, TMS Underdrive Pulleys, TMS/Carbonio Intake, Eisenmann Exhaust, AutoSolutions 30% SSK, BMW Illuminated Shift Knob, BMW Performance Pedals, BMW Performance 4.10 R&P, CDV Delete, Flossmann GTR Carbon Fiber Hood/Trunk, Carbon Fiber Rear Diffuser, Euro Front Signal Lights, Euro Rear Tail Lights, Angel Eyes, Homelink
1997 328is 5MT Coupe Madeira Violet on Black - Staggered M Forged Double Spoke Wheels, Bilstein Sport, H&R Sport, M Tech Rear Spoiler (Sold)
Jump to top bimmerdriver is offline   Reply With Quote
Old Sat, Dec-02-2017, 11:35:25 PM   #112
M3_Pilot
Two part question: would it be optimal to reset the ecu so it could adjust the vanos and timing to the new clearances? If so, how could I do that? Currently researching but any tips would be appreciated!
2004 Jet Black/Cinnamon 6MT
Old Sun, Dec-03-2017, 01:39:34 AM   #113
That's an interesting one. I've never come across a reset required since it operates within a certain tolerance of shim thickness and few thousands of an inch shim thickness change probably won't make a diff.
All DIY: 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Rogue RSM with reinforcement, WPC rod bearings, Beyer driveshaft, Magnaflow catback, new SAC/flywheel, rear main, VANOS bullet proofing with anti-rattle, valve adjustment, cooling refresh.
Old Sun, Dec-03-2017, 01:45:39 AM   #114
M3_Pilot
Yes, I see what you're saying. But that difference is also enough for us to have to make an adjustment. I suppose the ecu is also constantly adapting so it would adjust accordingly if necessary.
Old Sun, Dec-03-2017, 11:22:03 AM   #115
ThunderMoose
I don't see how the shims (within tolerance) have any effect on timing. The engine certainly doesn't know since it gets all of its information off the camshaft sensors which should not be impacted at all by valve clearance.
#67 2017 NASA TX TT3 Champion
Old Tue, Dec-05-2017, 03:27:10 AM   #116
M3_Pilot
Yeah that makes sense. Thanks for clarifying.
Old Fri, Jan-05-2018, 03:54:25 PM   #117
den_bart
den_bart's Avatar
Reputation: 0 den_bart is on a distinguished road
Are the specific cam lobes suppose to be facing up when taking off a specific shim?
Step 45 states to "Turn the 1/2" drive ratchet on the crankshaft bolt clockwise. You'll notice that the camshafts will begin to rotate. Keep rotating the camshafts until the first pair of cam lobes of any cylinder, exhaust or intake side, are pointing directly vertical. The smaller section of the cam lobe needs to be pointing directly vertical to the plane of the valve train."
It just says to have any of the cam lobes to be pointing up. But does the cam lobe that's facing up; is that referenced to the one that your changing the shim from?
Jump to top den_bart is offline   Reply With Quote
Old Fri, Jan-05-2018, 04:10:19 PM   #118
Yes, on the one you are changing the shim on, cam lobe should be facing straight up, you basically don't want any cam lobe to shim contact as you are adjusting the shim to set proper clearance. You also can't do intake and exhaust on the same cylinder with the same cam lobe position due to cam lobe overlap. So if you are working on cyl 1 for example and you get intake cam lobe to point straight up, you can do the intake valves but you will notice to do exhaust you need to readjust by turning the crank to get the exhaust lobes to point up. It's ok to turn crank counterclockwise also, if needed.
Old Sun, Jan-07-2018, 07:14:19 PM   #119
den_bart
den_bart's Avatar
Thank you! Your loads of help!
Sent from my SM-G925V using Tapatalk
Old Mon, Jan-08-2018, 04:48:09 AM   #120
Cheers, mate. Happy to help. Get 'er running!
Discussing DIY: E46 M3 (S54) detailed valve adjustment in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
