Mobile M3forum |
| E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#1 |
Recently installed Dinan springs and Konis in my 2001 M3. Replaced sway bar, Links, Right front control arm. Got the car aligned. Drives straight and perfect but theres a clunk in what sounds to be in the front left. I brought it to a very reputable indy shop, they disassembled the left front shock and found everything to look good. The weird part is that going over train tracks turning towards the left there is no clunk, only when turning to the right. At highway speeds you cant hear it, only going slowly over bumps. Any ideas??
Left front control arm? It appears to have zero play in the ball joint? Exhaust hitting? Shock top mount? Neither of these sound like the culprit with the turning right |
| Sponsored Links |
#2 |
Tie rod? My car is experiencing same thing and that was my guess
#3 |
After bringing the car in for the alignment they said I needed a control arm, so Im assuming they checked everything else in the front end and found nothing.
Possibly the shock bearing? |
#4 |
10-Year Member
![]() Location: Maryland
I don't think it's the exhaust. If you are certain this wasn't happening prior to the replacement suspension, something either is not seated properly or tight, or your FCABs have started to go out. End links are a common failure item, but you've replaced them and they don't make a clunking sound, more of a clicking.
///M3 - Dream Car: Acquired 2003 M3Laguna Seca Blue/6MT/Black Leather Cloth Interior/Full [CSL] Exhaust/evolve-R Original Owner, Custom Built - PDC, Moonroof, Bi-xenons, Brushed Aluminum Trim, Bluetooth ULF European - Rotors (F&R), Bumper, Mirrors, Warning Triangle, Console, First Aid Kit, Fire Extinguisher OE LED Conversion/Outer Ring Mod | V1 Hardwired/Ashtray Display | 3M 35% Tint | Diamond S600s, JL 10W3v3, HD900/5 |
#5 |
Flyguy
![]() Location: O'Fallon,IL
Are the endlinks tight? I had a similar sound and went back and tightened the end links a tad more and that solved the problem. Been quiet ever since.
Mike K. 2005 M3 |
#6 |
I had the front right FCAB replaced with the control arm. My mechanic said a bad FCAB would be noticeable under braking. Im going to check the sway bar links, take apart the shock and replace the bearing, top mount (guide support) and the rubber seats even though everything looks fine. I just hate buying parts to trouble shoot problems. Car drives super tight otherwise, very frustrating.
#7 |
Ended up being extremely loose FCAB bolts, no idea why they were so loose. Needless to say the way we figured it out was by just tightening every bolt in the front end, you'd be amazed what'd find loose.
#8 |
30 something
![]() Location: San Diego
That's scary! The Fcab is the only thing that controls fore/aft wheel position.
'04 46M 6MT || '01 330Ci 5MT |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
