Old Mon, Jul-16-2012, 11:59:50 PM   #1
DNYCEM3
IMOLA ON IMOLA BEAST!...
DNYCEM3's Avatar
Reputation: 0 DNYCEM3 is on a distinguished road
Angry Smg issue
So I've been posting on main thread, but no real help so here goes! car use to shift fine! Bought this car recently by the way I tried to power break the car to launch a little didn't do anything but give me trans light at low rpm not to much load at all and I went to park the car and tires slipped on grass being that they were bald....
And now at this point car is still on but won't engage any gear! So idk im sitting here thinking shut down maybe it cools off and goes back to normal but no car still does not wanna start 2 months later being this ain't my main m3 I only play with it when I have time,
I checked fluid level seems to mark max!
Replaced the salmon relay! And still car will not start"
Fully charged battery
Pump does prime when u unlock it with the keyless entry,
Smg light is on and get a blinking 0 from the moment ignition is on
Idk not no how to troubleshoot if the hood censors are bad....... Kinda running out of ideas I tried to scan with my obd2 scanner but no codes are showing up!
Thanks to any1 who gives input on this in advance DNYCE!
Update these are the codes I have pulled these 5
Finally pulled oem codes with regular 600 dollar scanner
P2805
Transmission range sensor a/b correlation
P0763
Shift solenoid c circuit electrical
P0900
Clutch actuator circuit/open
P1720
Manufacturer control transmission
P0901
Clutch actuator ckt range /perf
I hate myself for buying this smg model!
I had the clutch changed due to the shop telling me it was the issue now car does start on everycrank!.... but now the car no longer has 2nd 4th or 6th gear !!!!
Wtf I'm going nuts it had the gears before this issue and now I'm told to swap out tranny has anybody dealed with not having bottom gears I have reverse 1st 3rd 5th no bottom
IR/IR 6SPEED CURRENT!
AW/CIN SMG CURRENT!
K24 97 HONDA DELSOL CURRENT!
HPF SOON!!!
Jump to top DNYCEM3 is offline   Reply With Quote
Old Tue, Jul-17-2012, 12:08:23 AM   #2
M3ANMACHINE
HellaFunctional
M3ANMACHINE's Avatar
Reputation: 0 M3ANMACHINE is on a distinguished road
I'm guessing hood sensors.
But why did you try to "power brake" is my question...
E90 ///M3 - AW - 6MT - Volk - Akrapovic - Dinan
Originally Posted by F1 Game 2013 View Post
propchef says, "Hola? Oh Hi Lewis. Say what? You couldn't have gone any slower? Yea, I think I realized that WHEN I LAPPED you!! jajajaja!!!"
Jump to top M3ANMACHINE is offline   Reply With Quote
Old Tue, Jul-17-2012, 12:19:18 AM   #3
DNYCEM3
DNYCEM3's Avatar
Default Re: Smg issue
I would say mistake first smg car didn't really know about launch control! And all that....
And is there a way of checking if there bad or should. I Go ahead and just replace both!
AW/CIN SMG CURRENT!
HPF SOON!!!
Old Tue, Jul-17-2012, 01:11:53 AM   #4
sleeks
sleeks's Avatar
Reputation: 0 sleeks will become famous soon enough
You abused the clutch. When you were power breaking the clutch was likely taking the abuse. Let it cool off and see if the light goes off.
MY02 ///M3 - Steel Grey/Black
I am on my third E46 M3....yes, I am crazy
Gone:
03 Tiag/Black
04 Silver Grey/Black
Jump to top sleeks is offline   Reply With Quote
Old Tue, Jul-17-2012, 02:02:00 AM   #5
DNYCEM3
DNYCEM3's Avatar
I did it once maybe 2 seconds on both didn't even pass 2k and light came on doubt that was it mind u this happen2 months ago! So its had plenty of time to cool...
AW/CIN SMG CURRENT!
HPF SOON!!!
Old Tue, Jul-17-2012, 02:18:46 AM   #6
RedM3/4
Reputation: 0 RedM3/4 is a jewel in the rough
Hood sensors won't keep the car from starting. They will keep a running car from going into gear.
What exactly happens when you try to start the car? won't crank, or cranks but won't start?
ADS
98 M3/4, Supersprint catback, UUC red tranny mounts, Rogue SS w/UUC dual selector rod, wired V1.
Sold to my son, still in the family!
06 SMG/ZCP - April 09, Dinan over Konis, RAC RG63, homelink with off-delay (working), multifunction steering wheel buttons, RacingBrake Front kit.
Jump to top RedM3/4 is online now   Reply With Quote
Old Tue, Jul-17-2012, 02:41:14 AM   #7
DNYCEM3
DNYCEM3's Avatar
ADS
It does nothing atall just blinking 0. And warning lights
AW/CIN SMG CURRENT!
HPF SOON!!!
Old Tue, Jul-17-2012, 02:52:49 AM   #8
RedM3/4
You're going to have to get codes read by a diagnostic tool that is known for certain to read BMW codes and specifically SMG codes.
Is the car in neutral and will it roll? I'm thinking you may have hosed the clutch and it is stuck, not disengaging the flywheel.
ADS
Old Tue, Jul-17-2012, 02:49:03 PM   #9
DNYCEM3
DNYCEM3's Avatar
Yes the car moves if I push it with break down! Guess I'm gonna have to tow it somewhere....
AW/CIN SMG CURRENT!
HPF SOON!!!
Old Tue, Jul-17-2012, 06:02:18 PM   #10
DNYCEM3
DNYCEM3's Avatar
AW/CIN SMG CURRENT!
HPF SOON!!!
Discussing Smg issue in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
