Mobile M3forum |
| M3 Track: Racing and DE Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! |
#11 | |
![]() Location: Bay Area
Looks like you might be placing a next day air order with VAC Look at this PDF for the install, it lists everything you will need to know about getting the proper points/angles. The Scroth harness includes eye bolts w/ backing plates if you don't mind drilling holes for your belt mounts. http://www.schrothracing.com/docs/Co...structions.pdf
04 BMW M3 6spd - Alpine White/Black BBS LM w/ Michelin Pilot Super Sport's, Apex ARC-8 w/ Nitto NT-01's, TCKline D/A Coilovers, TCKline Camber plates, SPC Rear Trailing Arms, Reinforced Subframe, Brembo BBK (355mm front, 345mm rear), Rogue Engineering Transmission Mounts, Rogue Engineering RTAB's, Treehouse Racing FCAB's, SGT Headers, SGT Section 1, Dinan Exhaust, Vorsteiner V-CSL Bumper, Vorsteiner V-CSL Trunk, Vorsteiner V-CSL Diffuser, Kirk Racing Roll Bar, Recaro SPG, Scroth Profi 2 Harness |
| Sponsored Links |
#12 |
Get the VAC sub belt bracket and lap belt bracket. They both fit on the seat base and use existing bolts so you don't have to drill into the body of the car and mount eye bolts. I believe they are $39 each.
#13 |
![]() Location: SACRAMENTO
Has anyone ever used the vac sub bar on other brands of seat bases or it will just work on the vac floor mounts...
#14 | |
Seriously, what floor mounts are you using? I believe Macht Schnell also makes a sub belt mounting bar.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
