Mobile M3forum |
| E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#1 |
My water pump is on its way out. I found dried coolant all over the shroud, and has been accompanied by a cold start rattle. I would like to hear from people running the saleri or Re manufacturered pumps. IMO they couldn't be worse than the OEM....My car only has 43K on it.
Drive a Prius, I need your gas! |SG type intake|AA GEN3|Victory UDP|HPF Reinforcement|PF subframe bushings|Rtab limiters| |AC strutbrace|Eibach/Koni's| Last edited by NICKBRUM; Tue, Jun-19-2012 at 02:12:02 AM. Reason: Update |
| Sponsored Links |
#2 |
My pump went at low miles too. The saleri pump which if you look around on here I did a review on. Is pretty much a re-branded Lasso water pump. Has the metal impeller.
#3 |
Flappy Paddle Flapper
![]() Location: South Fla
I only stick to factory or oem for mechanical replacements. There are many reseller's who have these parts available at a fraction of dealer prices.
That being said I do not have any experience with the brands you have mentioned. The down side to 3rd party products is that you may be doing the job at sooner than you might want to. The relatively small cost savings will be negated at that point. 2c
AKA LordDRIFT (BF.c) ![]() I Love to Flap My Paddle |
#4 |
Don not to be sarcastic....but sticking to OEM when it is poorly desinged is something I would rather avoid. I'm not an anomaly here, as I have read of other early failures. Very frustrating when my DD is a F150 with 175k and counting. That's the vehicle that should need a water pump. Good thing that M is soo fun to drive, we sure deal with alot owning these cars.
Drive a Prius, I need your gas! |SG type intake|AA GEN3|Victory UDP|HPF Reinforcement|PF subframe bushings|Rtab limiters| |AC strutbrace|Eibach/Koni's| |
#5 | |
After failures in my e34 and identical ones in wife's e39: I started replacing cooling parts as a preliminary step in every BMW I have owned since then. I will say I have never had to replace cooling parts more than once. And since I've been sticking to the blue stuff in my cars< for the past 4 years or so> the cooling system wear has been top notch. The cooling system in my own e39 is a testament to this based on the type of mileage the new owner is racking up. If a 3rd party part goes belly up on me - which they have - I would kick my self in the nuts, because it would have been my fault (or so I would would be nagged). Oem goes belly, pretty much nothing I could have done (or so I will tell myself). ![]()
AKA LordDRIFT (BF.c) ![]() I Love to Flap My Paddle Last edited by Don Draper; Sat, Jun-16-2012 at 07:39:03 PM. |
#6 | |
Also keep in mind that there have been issues with the 3rd party water pumps too. Based on what I've read, I will be going OEM when the time comes. Search this forum for more info.
Do you wish that Double VANOS never existed? Vote! 2004 Silver Gray/Black M3 Convertible |
#7 |
I replaced my water pump around 50K with a OEM unit. The pump has been redesigned with a bigger shaft.
#8 |
lucky_doggg7
![]() Location: Lake Forest
My original water pump starting weeping coolant around 60k miles. I was lucky and it lasted all the way to 100k miles. For the replacement and like the others have said, I also used a BMW pump just for that bit of insurance. I bought the ECS Level 3 cooling system kit, plus a new fan clutch along with a new hose or two. Expensive, but it's good for another 100k miles!
#9 |
Literally passes gas for a living
06+ cars come with the updated water pump, if memory serves me correctly. That is the current OEM part, which is far more durable.
![]() 2003.5 TiAg ///M3 "Betsy," Black Nappa interior 120,000 miles and counting Stuff done so far Intake: Macht Schnell elbow, aFe ProDry filter, RPI scoops Engine:Denso Iridium UX024 Exhaust: Supersprint V2 Stepped headers, CPI pipe w/ 200 cell cats Cooling: Rogue silicone coolant hoses, Updated OEM water pump Brakes: TMS SS brake lines, CSL rotors Suspension: Koni Sport + OEM springs, Meyle HD RSMs, OEM RTABs + TMS limiters, Rogue FCABs, TMS rear camber arms, Meyle HD front swaybar links Drivetrain: UUC shifter Chassis/Frame: TMS rear subframe reinforcement kit, TMS rear shock tower reinforcement plates Exterior: Seibon CSL-style CF trunk (painted in TiAg), EurosportDesign clear front reflectors, Depo LED front corners, Khoalty projector foglights, VMR VB3 gunmetal, black side and kidney grills Interior: Khoalty LED interior/trunk lights Stereo: Custom Clarion navigation install |
#10 |
If there is one thing that will fail on a BMW, it is the cooling system.
I consider this a cost built into any BMW that I have not under warranty. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
