Old Sat, Oct-02-2010, 06:05:12 PM   #1
norwegianm3
norwegianm3's Avatar
Reputation: 0 norwegianm3 is on a distinguished road
Default Intake manifold
I purchased Stack electrical water/oil temp and oil pressure gauges to install and I have hit a sticking point with the intake manifold. It seems the Bimmerworld oil distribution/sending block I ordered mounts to the back of the oil filter housing which entails removing the airbox/manifold attached to the throttle bodies.
Anyone know of a DIY on removing the manifold? Here's a shot but I seem to be missing something simple because if feels like it's welded on.
Also curious about whether anyone mounts their oil temp sensor in a different spot? Have heard that between the pan and the oil cooler is the most accurate spot.
Thanks.
H Prepared E46 M3 : SSV1 & Catless Race Exhaust : BW Epic Tune : TCK DA Suspension : K&N CAI : Other stuff
"My fortune is small...and getting smaller." me
Last edited by norwegianm3; Sat, Oct-02-2010 at 08:33:52 PM. Reason: change of subject
Jump to top norwegianm3 is offline   Reply With Quote
Old Mon, Oct-04-2010, 05:10:33 AM   #2
toy4to
Lemonade Tycoon
Reputation: 0 toy4to is on a distinguished road
These two links will help you. I used those links when I removed mine during my supercharger installation. Warning, it's going to be a PITA.
http://m3forum.net/m3forum/showthread.php?t=310634
http://www.m3forum.net/m3forum/showthread.php?t=262263
Jump to top toy4to is offline   Reply With Quote
Old Thu, Oct-07-2010, 11:14:42 AM   #3
norwegianm3
Perfect, that's exactly what I was looking for, thanks!
Old Mon, Oct-11-2010, 06:20:59 AM   #4
MPOWERD
Mod Hound!
MPOWERD's Avatar
Reputation: 0 MPOWERD is on a distinguished road
Are you SMG or 6MT? If you are SMG its a bit more complicated of a removal as you will have to disconnect the SMG pump reservoir tube AND you have to be careful of the fluid as it will spill out of the reservoir from the top (the bottom seals shut when you remove the reservoir...
Removing the intake itself is fairly simple and strait forward, though I suggest you use a large set of needle nose pliars to remove boot clamps instead of [B] pliers, as they will likely fail during use.
AND make sure you have the boot clamps in place on the intake hoses BEFORE your reinstall the intake as it is a nightmare to try to add them afterwards...
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=91859&dateline=123241  4897
2003.5 e46 ///M 3 TiAg Cabriolet SMG II...
<> CSL Carbon Fiber Intake w/MAF, Brembo Gran Turismo, Euro Headers & Cats, K&N 69, Radenergie Carbon Fiber Strutbar
<> EAS Carbon Fiber Kidney Grills, Carbon Fiber Fender Grills, SMG Carbon Fiber Paddles, Vorsteiner 2 Sided CF VCSL Boot
<> EAS Slvr Carbon Fiber Interior Trim, Blk Carbon Fiber SMG Dome, Carbon Fiber Console, & Blk/Slvr Steering Wheel Trim
<> EAS Carbon Fiber Engine Bay, Vorsteiner Carbon Fiber Valve Cover, RPI Intake Scoops, CarPC w/Nav/MP3/HD Radio/TV
<> Eisenmann Race Exhaust, Supersprint X-Pipe with Resonator, Ekarbon 1/2 Carbon Fiber Diffuser, DEPO Smoked Corners
<> 19x8.5 19x9.5 VMR V710s in HyperSilver, Painted Corner Reflectors, EAS Carbon Fiber Emblems, Carbon Fiber Hood Vent
<> Slvr CF Pedals, OEM 2-Tone Hardtop, Windscreen, & Alarm, 6K Headlights & HID Fogs, Blk Carbon Fiber Headlight Trim
Jump to top MPOWERD is offline   Reply With Quote
Old Mon, Apr-25-2011, 01:09:31 PM   #5
norwegianm3
Default Re: Temp/Pressure Gauge Install
I finally got around to getting 2/3 of the job done. Since the original post I ditched the idea of the oil distribution block in favor of a simpler solution. I found an oil filter cap at VAC with two holes tapped, one for pressure and the other for temp. I am only using the cap to get oil pressure as I opted for the Turner Motorsport oil pan flange to pull oil temps directly from the bottom (it actually goes up into the pan a little ways) of the oil pan.
Now I just need to find a good spot, the best spot for a race car, to pull water temps and I'll be all set.
Installation is pretty simple for the flange and as easy as unbolting the oil filter housing cap and bolting on the new one. Here's links if you're interested.
http://www.turnermotorsport.com/p-37...or-flange.aspx
http://store.vacmotorsports.com/vac-...s54-p1065.aspx
Old Tue, May-01-2012, 04:27:11 PM   #6
metal_militia
metal_militia's Avatar
Reputation: 0 metal_militia is on a distinguished road
Did you ever get that water temp gauge installed?
Jump to top metal_militia is offline   Reply With Quote
gauge, install, temp or pressure
Discussing Temp/Pressure Gauge Install in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
