Mobile M3forum |
| E46 M3 (2001-2006) Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm Total Produced: 45,000+ - Years Produced: 2001 to 2006. |
#1 |
I am back to e46! I went from Supercharged 330i to e39 540 and now back to M3. This car is RAW! I love it. It's imola red with red seats. 6MT with 51k miles.
1. During driving, driver's side mirror shakes. Not the housing, but mirror itself. Is there an easy fix for this? 2. After car warms up, I hear some rattle/shake in mid section of my car as I am releasing the clutch. I haven't changed under for guibo/center drive shaft bearing but it doesn't really sound like it. Could it be something inside tranny? Oh the noise only happens of 1st and 2nd gear at low speeds Thanks in advance Couple photos: ![]() ![]() |
| Sponsored Links |
#2 |
![]() Location: Philly/S. Jersey
Nice car!
Don't know about #1, but I think the noise you describe in #2 may be typical. Mine does somehting similar. either that, or we both have the same bad part... |
#3 |
AwwwYeah!
![]() Location: Northern VA
I want your wheels!!!
![]() 2002 M3 | ESS VT1-455 | BW Race Exhaust | Hawk Pads | Ground Control Suspension | Whiteline Swaybars Custom Roll Bar | Stripped Interior | Bride | G-Force | SneedSpeed Adjustable Rear Wing | Front Splitter SneedSpeed Brake Cooling Ducts | D-Force LTW5 Wheels/Hoosier R6 | OEM Rear Square Setup w/ Nitto NT01 |
#4 |
#5 |
Great choice, but didn't you notice the problem before you buy it?
2004 M3 Silver Gray / CSL Header and Cats / SS Non Res. X-Pipe / RE El Diablo Exhaust / Hotchkis Swaybar / CDV Delete / KW v2 / RE RSM / OEM RTAB with TMS Limiter / RD Sport Rims 19' / Michelin Super Sport tires / Axxis Pads / Reinforcement Kit / Smoke Corner / Kamei Eyelid / 50% Tinted / Painted Shadow Grille / Umnitza Halo light / Hanman Lip / CF Diffusor / Side Clear Protector / Alpine CDE-103BT / JL Amp 500/1 / JBL Sub / Bimmian Mobile Dash Mount / CF Emblems / CF Side Grill / Euro Center Console Tray / Autosolution SSK 30% / Aluminum Foot Pedals / Chrome E-Brake / AA Shift knob / AA Sport Fan Clutch / AEM Boost Gauge / AEM Wide Band Gauge / Oil Catch Can / CF Wrap/ 3.91 diff / Aluminum Dipstick / OM Bootlid Active Auto HKS Gen 6 Level 1.5 |
#6 |
For #2, mine does that too on cold starts, but mine's smg so not sure if this applies to how you're releasing your clutch when accelerating after cold starts. I give it less gas/accelerate slower after I start the car. It usually only happens when the engine is cold within a minute or so after starting the car. Yeah, it makes a rattle and you think something is falling off the car, haha.
2005 SMG II. Imola Red Inside ![]() Stock Except for M Track Mode (with M Track Mode light in the cluster) and CSL software (faster shifts and launch control at 4800rpm), both via autologic Last edited by uscbeemerM3; Wed, Apr-25-2012 at 07:38:27 PM. |
#7 | |
Noob
![]() Location: Alpharetta
#2--This sounds like the beginning signs of a bad center support bearing. My car exhibited the same signs and then it got rapidly worse. Although, I would not expect the csb to go bad in 51,000 miles... There is not much else in the middle of the car that could make a noise like you describe (maybe a heat shield that is working loose). Good looking car! |
#8 |
Thanks for the feedback guys. I did notice small noise it at time of purchase but I drove down for 8 hrs and wasn't going empty handed lol
I will check heat shield and CSB over the weekend. I have a pit in the garage so it's super easy. P.S. I believe original owner of this car is on this forum, 02RedOnRed http://www.m3forum.net/m3forum/showthread.php?t=287312 |
#9 |
![]() Location: OC
looks great! Love imola but i dont think i could ever have a red car..unless it was a ferrari lol.
pit in your garage??? must be nice.. |
#10 |
2004 E46 M3
![]() Location: Costa Mesa
love it...
And there are some DIY's around for the mirror issue. I want an Imola red exterior car....
__________________ 2004 Mystic Blau Imola Rot ///M3 Coupe SMG Other Rides 73- 240z - L28 Block w e31 heads - prepping as a track toy 95- Legend Coupe - C32A5 block - totaled while parked 96- Dodge Ram 4x4 5.9 - totaled while parked in a seperate incident |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
