Old Wed, Apr-25-2012, 06:23:14 PM   #1
RND1
Reputation: 0 RND1 is on a distinguished road
Default E11 Torx on Bell Housing?
Getting ready to do the clutch and saw in one of the write-ups that a couple of the torx bolts on the bell housing are E11. I have a set of external torx, but they're all even. Can someone confirm I need an E11?
Lisle makes a nice set, but no E11. Nothing at Autozone, Napa, HD, Lowes, or Sears.
Jump to top RND1 is offline   Reply With Quote
Old Wed, Apr-25-2012, 06:30:16 PM   #2
Jrrrrrrr
M3 Boot
Jrrrrrrr's Avatar
Reputation: 0 Jrrrrrrr is on a distinguished road
Default Re: E11 Torx on Bell Housing?
You got a bum scoop.
The sizes you need are e10, e12 (starter bolts), and e14. The 7-piece e-torx impact socket set from HF has all those sizes, is cheap, and stands up to air tools.
Jump to top Jrrrrrrr is offline   Reply With Quote
Old Wed, Apr-25-2012, 06:36:03 PM   #3
RND1
Great, thank you. I already have these in my set, but I've wondered about the quality of HF (Pittsburgh) tools? Do they hold up?
Old Wed, Apr-25-2012, 06:38:59 PM   #4
enderw88
Craig
enderw88's Avatar
Reputation: 0 enderw88 is on a distinguished road
If you only need them a few times, they are fine. But really, they don't save you that much. Good tools cost you once, cheap tools cost you a thousand times...
Don't forget the rather extreme extensions and swivels recommended to get at the upper bolts.
95 BMW M3 Current Project
Cosmos Black, E46 6SP, VSL Rad, Stewart Water Pump, AA Header with 3" exhaust, aFe CAI, Euro HFM, 24lbs/hr injectors, unknown tune?, BW SS Brake Lines, Hawk HP+ Pads, M X-Brace, Mason Engineering Aluminum Strut Bar, MM Underpanel.
To Do: Overhaul rear suspension, front suspension
Tucson, AZ
Jump to top enderw88 is offline   Reply With Quote
Old Wed, Apr-25-2012, 07:44:36 PM   #5
RND1
What are we talking about here?
Old Wed, Apr-25-2012, 08:18:03 PM   #6
enderw88
Craig
enderw88's Avatar
See step 11 of the transmission removal DIY
That is written for a Z-3, but there aren't many differences in this part of the car.
Tucson, AZ
Old Wed, Apr-25-2012, 08:23:24 PM   #7
Jrrrrrrr
M3 Boot
Jrrrrrrr's Avatar
I just so happened to have the HF e-torx set, and as said, used it with air tools. There are definitely better sockets out there, but they'll suffice if you aren't a professional mechanic who uses them regularly.
Old Wed, Apr-25-2012, 09:08:06 PM   #8
RND1
This is the DIY I was referring to citing the E11 torx. So, that is only for the Z3?
Old Wed, Apr-25-2012, 09:22:47 PM   #9
enderw88
Craig
enderw88's Avatar
I can't speak specifically to the Z-3 using an E11 in those spots, I think that part is wrong, but the rest of the DIY looks applicable to any E-36. It is interesting that they refer to E12s and E11s so maybe the Z-3 does use E11 there but I have never seen an E11 (or any odd number, for that matter) socket...
Really, except for tricks like the long extensions to reach the top bolts, removing a transmission is removing a transmission:
  1. put the car on jack-stands
  2. drop the drive shaft
  3. pull the shifter/other trans connections (speedo drive/reverse sensor/slave cylinder)
  4. support the transmission (and engine if the trans bears weight)
  5. remove the bell housing bolts and transmission mounts
  6. slide transmission back and out
The only variation is on cars like my Super-Stalker that required the engine/transmission to come out a a unit before disassembly.
Here is a good thread about how high the car needs to be to remove the transmission without heroics.
It is laborious, but doesn't require any really special skills.
I haven't done this particular job on my M3 yet (next month I put in the E46 trans), but I trust the advice here about the E12 sizing. I will have to pick up another 1/2" extension to prep for the job.
Tucson, AZ
Discussing E11 Torx on Bell Housing? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
