BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) (http://www.m3forum.net/m3forum/index.php)
-   Southwest (http://www.m3forum.net/m3forum/forumdisplay.php?f=41)
-   -   Houston Shop Familiar With SMG to Manual Swap (http://www.m3forum.net/m3forum/showthread.php?t=548764)
mike4-vr6 Mon, May-16-2016 06:13:21 PM
Anyone know of a shop local to Houston that has swapped an E46 M3 to manual?
s.strehler Tue, May-30-2017 06:15:34 PM
Re: Houston Shop Familiar With SMG to Manual Swap
Di you ever get any info on this? Looking for someone to do my coding after the conversion.
Asianinja11 Tue, May-30-2017 09:12:32 PM
Talk to Sam. He owns Texas Auto Fleet, he worked on my M installed Active Autowerkez headers and tune.
713-478-5647 (Tell him Earl referred you)
s.strehler Tue, May-30-2017 09:54:08 PM
Thank you for your help.
ThunderMoose Sat, Jun-03-2017 01:34:31 AM
ABRHouston.com
jcanales Fri, Dec-21-2018 02:05:58 PM
1 Attachment(s)
Hi Mike,
My SMG has started to go south on my M3 as well. Once in a while it works fine for a week and then decides to hibernate which is why Iím here reading your post.
Did you ever find a shop to swap/convert your M3 to a manual in Houston? If you did, about how much did that run? From my understanding, ďyou do NOT need a new tranny for the swap, only the bell housing from the manual tranny which allows for detent/locking pins for centering the leverĒ.
https://jalopnik.com/how-to-own-a-bm...t-t-1747802451
From what Iíve read, quite a few people have done the conversions in Northern California. They have been very happy with the cost and results.
http://www.m3forum.net/m3forum/showthread.php?t=593288
Unfortunately, there were no shops mentioned in Houston that have done this type of work.
I took ThunderMoose's advice and contacted ABR Houston. They couldn't give me a quote over the phone until I brought the car to them. I spoke to Alex. He says heís done a conversion before, but it was a while back and donít remember who it was for. He did say at the bare minimum he can probably do it for is above 5k using spare parts. This seems somewhat reasonable as I figured the conversion should cost less than the cost of swapping out the SMG pump and accumulator.
This week, I received an email from the shops service agent with an estimate before moving forward with the work. The estimate did not reflect the amount that was discussed. Iím told that they have a high standard that would rival how the vehicle was built from the factory. The estimate is 1.7x more.
This turns things around for me. It now seems cheaper to go with an SMG replacement. Since the manual conversion is going to put me out of budget, my friends have suggested just changing out the SMG pump motor as indicated on the thread below.
http://www.m3forum.net/m3forum/showthread.php?t=550529
I presented this option to the service agent, but he doesnít think that this is something that the technician will be willing to do but will consider. Before he could consider, he would have to perform an advanced SMG diagnostic. This was performed but the technician had no confidence in identifying a problem with the smg pump or accumulator.
From my experience with the car, I am not leaking any hydraulic fluid. When the SMG is working, I can hear the pump motor prime and when it doesnít work I donít hear it prime when I unlock the car.
I really like the car with intent to keep it. I hope you guys can chime in on this and let me know what you guys think. Should I move forward with the manual conversion, have them do a SMG swap, or get my car out of there as fast as I can and take it somewhere else.
Also, let me know what you think of the estimate. Is it reasonable? Iíve attached todayís parts list of items needed for the conversion. Am I missing things from my parts list that i should consider?
Am I getting taken for a ride? I am told the labor for the manual conversion is 2500. I assume the rest of the cost is parts and reprogramming.
SQ13 Fri, Dec-21-2018 06:06:15 PM
Get in touch with Roman at Boost Logic. They’re in Austin, but Roman and his guys are very knowledgeable, know the E46 well, and I believe they’ve done a few manual swaps. Their pricing is much better than ABR’s, and they’ve treated me well.
jcanales Mon, Mar-11-2019 09:18:14 PM
Thanks for the suggestion and for everyone that sent me a private message on their recommendations. To update you all, after getting the car back, I ended up ordering a new smg motor and swapping it out myself. It took a lot of patience when working with tight spaces and getting creative to get to the two screws that hold the motor. In the end, I got the smg motor swapped out, and the M runs GREAT! No issues so far in the past 30 days. I'll link the motor and DIY thread in case anyone wants to try this approach.
For those interested in finding a place to do the conversion, take SQ13's advice if you are in the Austin area. Boost Logic with Roman. For those in Houston area, talk to Josh Harper at the European Motor Gruppe - 832-998-7700.
I would have gone to European Motor Gruppe the first time around but didn't find out about them until after I already did the smg motor swap. I still plan on doing a manual conversion but will wait till i put some more miles on this smg motor. Josh quoted me a reasonable price for parts and labor. All OEM parts.
Thanks everyone!
SQ13 Fri, May-17-2019 04:35:56 PM
FYI, Boost Logic does not do manual swaps anymore, so I’ll have to search for an alternative.
Lingsweiler Fri, Jun-14-2019 06:57:55 AM
Originally Posted by SQ13 (Post 1067957362)
FYI, Boost Logic does not do manual swaps anymore, so Iíll have to search for an alternative.
Do you need a place in Austin to get it done? I'm about to get it done in cedar Park area by a guy who specializes in the s54 motor. His shop is called Hill's performance bimmers.
