BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) (http://www.m3forum.net/m3forum/index.php)
-   E36 M3 (1992-1999) (http://www.m3forum.net/m3forum/forumdisplay.php?f=10)
-   -   Trunk edge plastic trim protection (http://www.m3forum.net/m3forum/showthread.php?t=574625)
UDPride Thu, Mar-30-2017 07:08:37 AM
Did the search, Google, etc.
Does anyone know how to get these plastic protector-type trim pieces off of the edge of the left and right trunk jams? They are on there pretty doggone good (won't peel away like a sticker). As you can see mine are severely cracked/faded and I want to replace them as I tidy up the trunk. Probably a non-issue for most, but nonetheless....
I thought about using a heat gun to try to toast them up a bit and then get a plastic pry tool under them to scrape them off. Someone must have tackled this and gotten them off somehow.
And I will need a part # for replacement. I assume everybody has these and they are a BMW part?
Thanks.
https://c2.staticflickr.com/4/3715/3...c3588589_c.jpg
LockDots Thu, Mar-30-2017 10:36:24 AM
Re: Trunk edge plastic trim protection
Have you tried realoem.com yet? Personally, I've never seen that.
UDPride Thu, Mar-30-2017 09:10:42 PM
Looked on RealOEM but nothing jumped out. Mostly just sheet metal and fasteners. The plastic strips do not have any part #s etched on them. I assume its a factory piece however. They seem precisely cut for the job they are doing and are on both sides of the trunk jam edge.
Its a sedan, dont know if that makes a difference. I gotta think others have these too?
LockDots Thu, Mar-30-2017 09:55:12 PM
It's possible it was part of the wing's install kit.
fiveightandten Thu, Mar-30-2017 10:30:52 PM
I pulled them off with my fingers and cleaned it up with goo gone. They didn't put up much of a fight and my car was a garaged 90K mile car when I did it. They weren't weathered at all.
scoobiedoo2029 Thu, Mar-30-2017 11:43:16 PM
mine are in the same condition as OP. i never found a replacment part, but the 3m clear paint protective stuff seems like the ticket, theres a spray on too that 3m makes and maybe it dosnt suck. i was thinking of using it and just taping off the original and removing it and spraying the exposed area. enless someone can get a peice off intact i cant see another method of easily duplicating the shape and placement exactly.
LockDots Fri, Mar-31-2017 10:09:30 AM
May not be a bad idea to place it on the bottom of the "wing tips" that comes into contact with that area. This way the protection is still there but unseen.
